longblock454
- Nov 28, 2004
Looks like HighPoint makes some 8x cards, but not IT mode, I'm looking for something that is completely transparent. Like the good ole ibm m1015 days.
In order for that to work, would the motherboard also have to support special PCIe bifurcation too? Like I've seen x16 slots be able to bifurcate down to x4x4x4x4, x4x4x8, or x8x8 but you would need x2x2x2x2x2x2x2x2 theoretically? Giving each NVME drive a dedicated x2 lane from the x16 slot.Looks like HighPoint makes some 8x cards, but not IT mode, I'm looking for something that is completely transparent. Like the good ole ibm m1015 days.
They use a custom asic doing pcie switching to get around the bifurcation problem. A dumb adapter does need x4x4x4x4 and you wont find one for 8 drives. The additional asic may limit speeds, require additional drives, and cause other issues.In order for that to work, would the motherboard also have to support special PCIe bifurcation too? Like I've seen x16 slots be able to bifurcate down to x4x4x4x4, x4x4x8, or x8x8 but you would need x2x2x2x2x2x2x2x2 theoretically? Giving each NVME drive a dedicated x2 lane from the x16 slot.
It's available now but the 16 slot version is notNot available yet, but a (21) slot card is on the way.
