Do 4kn hard drives require hardware support?
rigurat
Is the compatibility of 4kn hard drives software dependent? Or does the hardware (chipset, controller) matter?
When using 4kn drives on slightly older (pre advanced format) systems, does the chipset, drive controller, or RAID controller need to be 4kn aware? Or as long as the OS supports it, it should work fine?
The OS needs to support it for sure. For example, VMware vSphere does not at all which is absurd in this day. If using a controller then it should support them as well or your asking for problems. But I have used 4K drives on RAID controllers that don't say they support but also don't say you can't use them and I didn't have any problems at that time.
You need both controller and OS support.
Were they 4KN(ative) drives though? Most of the 4K drives still come as 512e(mulated) to remain backward-compatible.
I ask because I'm considering buying the HGST He8 SATA drive. It's an 8 TB drive, they sell both 512e and 4kn versions.
If compatible, I might as well get the 4kn version.
Although I don't plan to do this, what happens if you mix 4kn and 512e drives in a RAID setup?
The last generation or two of Enterprise drives have generally been available as 4Kn and 512e.
I have one plugged into my linux based pvr which is a core2quad on an ASUS P5Q Pro. It works without any issue on the Intel ports. It works fine with 4K native sectors.
Code:
jmd0 ~ # gdisk -l /dev/disk/by-vdev/5t0
GPT fdisk (gdisk) version 1.0.1
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/disk/by-vdev/5t0: 1220942646 sectors, 4.5 TiB
Logical sector size: 4096 bytes
Disk identifier (GUID): 2DA8C395-4AEB-3A42-B8B9-142E81BBC30E
Partition table holds up to 128 entries
First usable sector is 6, last usable sector is 1220942640
Partitions will be aligned on 256-sector boundaries
Total free space is 2859 sectors (11.2 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1            2048      1220925439   4.5 TiB     BF01  zfs
   9      1220925440      1220941823   64.0 MiB    BF07
Code:
jmd0 ~ # smartctl --all /dev/disk/by-vdev/5t0
smartctl 6.4 2015-06-04 r4109 [x86_64-linux-4.3.5-gentoo-20160210-jmd0.comcast.net] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     TOSHIBA MG04ACA500A
Serial Number:    deleted
LU WWN Device Id: 5 000039 57b801418
Firmware Version: FP1A
User Capacity:    5,000,981,078,016 bytes [5.00 TB]
Sector Size:      4096 bytes logical/physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Feb 12 08:08:07 2016 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
I could not use it with a USB2 dock however.
I looked at this when buying drives for my new NAS/"server" a few weeks back. I couldn't come up with any reason to go 4Kn over 512e. Even if everything supports it, there's no benefit that I could find aside from not needing a GPT partition up to 16TB. However, programs that want to access the disk(s) directly using 512byte sectors may not work at all, may run erratically, etc. The 4Kn versions of the drives were more expensive to boot.
Exactly, this is what stopped me from considering 4kn for now. Since 4kn requires end-to-end support, I thought it was perilous to build a RAID array with 4kn drives. If you ever need to (god forbid) perform drive-by-drive recovery, you'd need to ensure that you have compatible hardware and compatible software (some of which is proprietary).
OP: just a reminder that there's no performance penalty since the drives have fast internal processors that perform the 512-"logical"-to-4096-physical mapping. You just have to be a little careful when you partition the drive/volume to ensure proper 4k alignment.
arent 4kN drives signifcantly more reliable by means of error correction?
its two years later now. any of you guys had some 4kn experience? Whoever I ask tells me that if a NAS or a system controller and OS supports native 4Kn, I should go and use this format. VERY wierd thing is that they are not available in distribution nor in stores. Almost always special order. 6 weeks+ waiting time. Thath means very few people are buying them
Not really different than 512e in that. I expect that most drives today are 512e.
I don't have 100s of 4kn drives so my experience is not that useful in determining anything with statistical significance.
so to make it fast and simple - if you were to build your home NAS today, using Synology/QNAP that can use any type od a drive, what drives would you put inside? 512e or 4Kn?
It would be HGST drives of any type. Probably 512e since that will be more common.
512e drives don't have legacy compatibility issues (e.g. booting with a traditional BIOS) and they perform the same as 4kn. Only buy 4kn if it's cheaper.
thanks for the input, guys.
Now I wonder which series to buy - new 7K6 or older, but verified by thousands of users, 7K6000. From what I read 7K6 has higher cache, lower power consumtion and only 4 platters (6TB version) vs 5 in 7K6000.
7K6
0B36039
HGST HUS726T6TALE6L4 3.5in 6000GB 256MB 7200RPM SATA ULTRA 512E SE
0B36040
HGST HUS726T4TALE6L4 3.5in 4000GB 256MB 7200RPM SATA ULTRA 512E SE
7K6000
0F23001
HGST HUS726060ALE610 3.5in 6000GB 128MB 7200RPM SATA 512E ULTRA ISE
or cheaper and only with a 3 years warranty NAS version:
0S04005
HGST NAS H3IKNAS400012872SWW 3.5in 4000GB 128MB 7200RPM SATA HDN726040ALE614
I wonder if someone had experience with Enterprise drives and home/SOHO NAS such as synology configuring them for power saving that is head parking/sleep mode?
