Originally posted by SarverSystems
Wayne is incorrect in his wiring.
Red = +5VDC
Black = ground
Black = ground
Yellow = +12VDC
We've been down this road a jillion times, and yet people still think the 2 grounds are somehow different. That's why they have color codes. Black = ground no matter where you are in the computer. If ya don't believe me, take a look at any PSU and look at where the wires connect inside. Or better yet, wait for all the replies to back me up.
-5VDC is white if i recall and -12vdc is blue if i recall. Both are located on the ATX connector.
http://www.asus.com.tw/inside/Techref/images/atx-conn.gif
Because the 7 volt mods ground the 12v rail to the 5v rail, making the potential across them 7 volts. With a cable that does that, you don't want to use it on anything other than fans or it will mess up your grounds.Originally posted by wayne
but what about those 7v fan mods reviews? they always say to make sure not to mix up the wrong grounds? if thats true, then how am i wrong?
Right, but if you rig up an extension cable to convert a fan to 7 volts, you don't want to use that cable for anything but a fan because it moves the grounds.Originally posted by SarverSystems
You don't use ANY ground wires for the 7V trick.
No it doesn't. Think of ground as 0 volts. You have 0V, +5V, and +12V. If you hook up a fan across 0V and +12V there is a potential of 12V across the fan. The 0V line is still 0V and the +12V line is still +12V. Now, hook the fan up to +5V and +12V and there is a potential of 7V across the fan. The +5V line is still +5V and the +12V line is still +12V. There is no moving of grounds, whatever that means. All the lines are connected together inside the power supply so all 12V lines are the same. Adding an extension cable does not isolate itself from the other cables.Originally posted by Acceptable_Risk
i meant in the reviews, they remind people a LOT to not mix up the ground wires or else if you hook up other things, your gonna have problemsOriginally posted by SarverSystems
Well, they're just plain wrong. If you doubt, get a continuity tester and check the two grounds on a molex. It should indicate a short.Originally posted by wayne
but another review that points this out more is the ones that teach you how to change the molex connector into UV reactive ones (if you want, i can find you several reviews that say so) and they state very clearly and strongly to NOT mix up the ground wires because it takes in different voltages because power supplies are like that and not to mix grounds up and so
Whoever said that is quite ignorant. It was probably one person who started that myth and then other people read his "guide" and wrote up their own "guides" and perpetuated this stupid myth. It really goes against logic and common sense. Don't believe everything you read.Originally posted by wayne
so if all grounds are the same, that means they can 'absorb' any loose electricity...rite?if you are really worried about it just use the inside of your case as a ground. it is just like a car, you can use anything as a ground, IE. my amp is grounded to the trunk floor, and it works flawlessly.
A
L
L
G
r
o
u
n
d
s
A
r
e
T
h
e
S
a
m
e
It never has and never will be different
I really have no idea what you are talking about. Ground is ground because there are literally rods driven into the ground that the ground line is connected to. There is no "ground" on a battery, but people usually call the negative pole of a battery "ground". If you hook the negative side of a AAA up to the chassis of a dryer then nothing happens. The dryer doesn't "absorb" any electricity from the battery. There is no current flow. You can hook up a light bulb between the positive side of the battery and the dryer chassis and current will flow and the light bulb will light. Likewise, you can hook the positive side of the battery to the dryer chassis, and hook the light between the negative pole of the battery and the chassis. Hooking up the battery does not change ground. Nothing changes ground. Electricity is all just potential differences which cause current to flow.Originally posted by wayne
so if i connect an AAA batterys ground to anything to be used as ground... even if its the ground of some big appliance like a dryer or something?
i meant letting the ground or negative side of the AAA battery absorb all the stray electricityOriginally posted by jpmkm
yea, i kno what you mean about using the inside of the case for ground since powersupply is metal and then if you open it up, the actual ground is connected to the power source (household volts)if you are really worried about it just use the inside of your case as a ground. it is just like a car, you can use anything as a ground, IE. my amp is grounded to the trunk floor, and it works flawlessly.
