dmidecode (MAXSPEED)
P4rD0nM3
Hey guys, for those of you running GNU/Linux have you ever ran dmidecode to check your hardware info?
Dmidecode reports information about your system's hardware as described in your system BIOS according to the SMBIOS/DMI standard (see a sample output). This information typically includes system manufacturer, model name, serial number, BIOS version, asset tag as well as a lot of other details of varying level of interest and reliability depending on the manufacturer. This will often include usage status for the CPU sockets, expansion slots (e.g. AGP, PCI, ISA) and memory module slots, and the list of I/O ports (e.g. serial, parallel, USB). - Taken from their website www.nongnu.org/dmidecode/
I usually run it to check what kind of hardware I have when I'm about to upgrade my hardware.
Code:
Handle 0x0001, DMI type 4, 35 bytes
Processor Information
        Socket Designation: J1PR
        Type: Central Processor
        Family: Pentium D
        Manufacturer: Intel(R) Corporation
        ID: F6 06 00 00 FF FB EB BF
        Signature: Type 0, Family 6, Model 15, Stepping 6
        Flags:
                FPU (Floating-point unit on-chip)
                VME (Virtual mode extension)
                DE (Debugging extension)
                PSE (Page size extension)
                TSC (Time stamp counter)
                MSR (Model specific registers)
                PAE (Physical address extension)
                MCE (Machine check exception)
                CX8 (CMPXCHG8 instruction supported)
                APIC (On-chip APIC hardware supported)
                SEP (Fast system call)
                MTRR (Memory type range registers)
                PGE (Page global enable)
                MCA (Machine check architecture)
                CMOV (Conditional move instruction supported)
                PAT (Page attribute table)
                PSE-36 (36-bit page size extension)
                CLFSH (CLFLUSH instruction supported)
                DS (Debug store)
                ACPI (ACPI supported)
                MMX (MMX technology supported)
                FXSR (Fast floating-point save and restore)
                SSE (Streaming SIMD extensions)
                SSE2 (Streaming SIMD extensions 2)
                SS (Self-snoop)
                HTT (Hyper-threading technology)
                TM (Thermal monitor supported)
                PBE (Pending break enabled)
        Version: Intel(R) Core(TM)2 CPU          6320  @ 1.86GHz
        Voltage: 1.6 V
        External Clock: 266 MHz
        Max Speed: 4000 MHz
        Current Speed: 1866 MHz
        Status: Populated, Enabled
        Upgrade: Socket LGA775
        L1 Cache Handle: 0x0004
        L2 Cache Handle: 0x0002
        L3 Cache Handle: Not Provided
        Serial Number: Not Specified
        Asset Tag: Not Specified
        Part Number: Not Specified
Did you guys notice something?
Max Speed: 4000 MHz
