DLink Router NAT
p0lish
Can someone explain to me how my router can use NAT to simulate one computer, or one connection to the server? Im at college, and it is okay for us to have a router for multiple connections, but the internet login is needed for the internet to be accessed. I cannot use the PPoE to login. I need to login from my main computer, and allow the rest of my computers to have full internet capacity. I tried and cant seem to get it right. Here is a link to the manual if that helps explain things. Someone mentioned using a MAC address clone? I really havent had to do anything like this before and would appreciate any and all help.
Thanks in advance,
Bill.
ftp://ftp.dlink.com/Gateway/di624_revB/Manual/di624_manual_103.zip
The manual is missing a crucial picture. You should have a spot for a username and password on the same page you enter the ip address. That should be all you need to access the web with all systems using that router. Thats how my Linksys is...even though I don't need to login on my cable connection.
