Wii Component Cable - Composite 1
This means you have a poor connection on one of the color channels or the ground on one of them.Devnull said:I almost got it to work now. When I jumper pins 8 and 10 together it switches from composite output to component on the wii. But the picture is distorted, garbled and the color is either black and white or screwed up colors.
kumquat said:I dunno. Getting the cover off was the hardest part for me.
I literally just shoved the paper clips into the right holes, clipped then to a set of cables, and that was it.
Like I said, I'm not very mechanically inclined. I usually break stuff. But this "just worked."
What part did you have trouble with?
Neither did I. I just shoved them in and it worked.jamesrb said:Although looking at a couple of posts above, I did not notch the paper clips like in the picture...
jamesrb said:I don't know. I put in all of the paper clips, attached the wires and everything, but never got anything but a 'no signal found' on my component input.
Heck, after removing the paper clips, I couldn't even get the wii to come on. Unplugging the power and plugging it back in fixed that though.
I just hope I didn't short something to where it won't work when the real component cable comes in.
kumquat said:This means you have a poor connection on one of the color channels or the ground on one of them.
I think it's probably a *lot* easier with the preassembled jumper wires. Just go through and make sure nothing is touching and all your connections are sound.
Could very well be the cable you're using. An audio RCA cable may or may not be the 75 ohm cable required for video. Most seem to do OK, but many work very poorly.Devnull said:I just tried attaching the bare wires from my cable to the paperclips with aligator clips... The result was about the same as before. Screwed up garbled video, bad colors etc. I am thinking maybe the problem is the RCA cable I cut up to use as a component cable. Or the paper clips won't make good contact. I am not going to cut up my good component cable, so I think I am done unless anyone has any other ideas.
j92s said:does anybody know if the gamecube connector is the same as the Wii? If so, WalMart sells them for like $8..... that way it'd be cheap and easy to make your own cables without touching the originals....
if they're the same I'm gonna make some today. Figure i can just fill up the orifices with epoxy to make it permanent
