DIY Vapor-phase cooling....
Tim Wardlaw
Hey all, I got my hands on an old water cooler, you know the kind you get drinking water out of at work? Anyway, I'm going to try to convert it in to a vapor-phase cooler... but I have only one question... does anyone know if the compressor can be refilled with coolant? Because I want to cut the HUGE rad off and put a more compact one on, as well as put a block in place of the evaporation plate. Anyone with info or if you have attempted this in the past, your comments are welcome here... once I get this done I’ll post up some pics and stuff. Thanks all
try the forums at xtremesystems.org, thats the sort of thuff they tend to do over there.
yeah this is much better suited for the phase change section at xtremesys.. except the site does indeed appear to be down.
