MindBuster
- Jan 6, 2002
I want to power a digital picture frame from usb and got it working, sorta, when it's just showing a pic everything is fine, but when it transition from one pic to another I get some flickering, as if it doesnt get enough power (it does the job though, I just dont like the flickering).
It comes with a 5VDC 1000Mah wall-wart, the back of the frame says it draws 4 watts.
First I tried just powering it from USB 5V+ and GND, which didnt work, it didnt boot, as USB only supplies 100Mah, up to 500Mah when requested for it, but the frame has no way of telling what it needs.
Then I put the port in "Charger Mode" by shorting the two data lines, which work, except for the flickering when changing pics.
So I want to make a USB Y Cable, to get power from two ports, and was wondering if it's as simple as just combining 5v+/5v+ and gnd/gnd. or do I need some sort of diode on one of the 5v+ lines ?
Also, is the shorting of the data lines I did, safe enough, or do I need something in between those also ?
