DIY Smart Vacuum Cleaning Robot
LOL that was a class project for one of my upper level classes for CS degree. Make an intelligent 'roomba' that would navigate a room with obstacles, while crossing the same path as little as possible. All using the Lego mindstorm flashed to support java. But it only had a TINY ammount of storage, so you had to get creative with how you mapped the room in your code.
Botvac > Roomba > This
True. Neato (makes the BotVac, iirc) did a bang up job on that. At the time of its release, it was the first consumer product with SLAM technology at a cheap price. Many were bought just for the chipset/module. Roomba still operates on the random bounce principal (I think they still do), where the bot will drive in a line until it's sensor detects something, then it'll change to a random direction that is not the prior one, rinse-repeat. The BotVac actually maps the environment with the laser unit and then calculates an efficient cleaning path.
I'm kinda surprised no-one has made a self cleaning robot vacuum. One that when it docks for charging, has the inner dust tray emptied. I can think of quite a few ways to accomplish that task.
