Diy second rad mount for TT p3
mord
Adding a custom water loop to my p3 case in stages. Getting ready to add another GPU block. Wanted more than a 360 rad for it to stay cool.
I'm adding a 420mm rad at a 45 deg angle along the top. Using black iron pipe to support it. I needed a way to attack the rad to the pipe.
I looked at pump mounts that bolt to fan screw patterns, but I wasn't convinced they were strong enough to hold a 420, fans, and water.
So I made my own. Looks dont matter much, this is the back side and will be hard to see unless you climb up onto of my desk and lean over the back of the rad.
