DIY Radiator Stand
Fuganater
I saw the Phobya stand and I really really liked it. Which fits 3x 3.120 rads or a 4x180 rad, but its $90. And they have a smaller one, which fits 2x 2.120 rads and its $60.
They have options which are great. You can mount your res and pump to the outside or inside of the rad stand.
So why can't I make it out of pelxi? So after a few hours in sketchup. I came up with this.
Inside the rad stand. You can see where the Rads go.
Outside the rad stand. Here you can see where the fan holes need to go.
I actually think I may be able to just cut the openings by hand and then just use some modders mesh to cover the holes. That will be way cheaper in the long run as I won't have to ship the plexi out and pay for a laser cutter and I can do it in 1 big piece.
Here is how I will cut the fan holes. All I did was make an X across where the fan hole needs to be (mounting hole to hole) and then drew a 2 5/8" hole there. Delete the parts that are outside the fan hole and there you have nice rounded corners. Should be easy enough to make if I take my time.
As of right now the feet are 8" long and 2" wide.
Total dimensions are :
1' 7" tall
1' 5" wide
4" deep (might make this 5 for thicker rads)
All materials are 1/4" thick acrylic.
So I'm going back to the acrylic idea. 1/4" is more than thick enough to handle the weight of the rads. + I will have rad grills made to give it some more strength.
The new feet. I'm 100% sure these will keep it sanding.
And the cutouts for the rads.
I got replies for the aluminum and just having the main pieces cut will cost over $140 so alu is out.
I just sent some emails to plexi companies to get work done. Hopefully I'll have a reply tomorrow.
Comments and advice welcomed. Cheers till then.
Here is the design for my rad grills.
Next up are the mounting holes for rads and pumps.
This measurement is actually wrong. Its 1 3/16" between the 2 holes, not 1 1/4"
Here it is drawn on the stand. These holes match both a DDC and MCP pump. DDC pump is sideways though but I won't be using one. The holes in the middle are for the EK Res. I like theirs the best and they only need 1 mounting point per res holder.
I could also make holes for the DDC pump to face the correct way but as I said, I won't be using it.
More soon.
Not much progress yet but I got my fans in.
18 Yate Loon High Speed fans
Testing the first batch.
They all work!
2nd batch.
All good agin.
Wiring is a mess. I will be removing the molex connector plugs because I don't need them with the fan bus'.
Now I'm just waiting on the fan grills to arrive and for my acrylic supplier to respond back about laser cutting the parts.
Cheers till then.
I have been gone for several months now but I'm only back for a few days. Since I was gone I received a few pieces of plexi, not the whole order, but some.
The custom made rad grills.
The sides and feet.
The holes line up perfectly!
The holes in the feet and the sides are for hoses to go through or for some Koolance Quick Disconnects. I have the threaded kind so I can actually mount them into these holes.
That's it for now. I'm going on vacation and I hope to have the rest of the plexi when I return so I can really get started on this.
Cheers till then.
Finally got in the last 2 pieces of acrylic in! My order was not fully filled 2 months ago and since I have been gone I was not able to receive the pieces.
I wasted no time and started drafting up the design on the main sheet.
In order to make sure I had the holes lined up perfectly, I used a 360 rad template that I bought from MNPCTECH. This proved to be an awesome investment and I recommend it to anyone that is going to be making radiator cutouts.
2 down and 1 to go!
I lined the rads up on the acrylic to make sure I had enough clearance between them and on the sides.
And finally the 3rd done.
Next I drilled the holes for the screws. I did this first because I was afraid that the acrylic would crack if I tried to drill after I made all the cuts.
Then I installed the fan grills, fans and rads to make sure everything lined up perfectly. And it did!
Here is what it will look like with the sides on.
At the bottom of the sides, you can see the 2 holes for the cables and tubing. I actually need to cut this layer out but more on that in my next update.
Hopefully tomorrow I will be doing all the cutting and gluing. I may get this done by Sunday!!
Cheers till next time,
Fuga
Neat! Looking forward to seeing the beast assembled. Going to be any pictures of the test bench included?
Time to cut, but first, I had to drill a bunch of 1/4" holes in the pattern so that I could fit my jigsaw in.
Took me about an hour to cut all 3 holes.
Here are the markings I made on the sides. I thought the threaded quick disconnects had a larger thread but they don't. So I have to cut away some of the side so that they will fit. I did it on both sides just in case I change something up one day.
Both sides cut.
Now its time for glue!
Top glued on. I let it sit for a bit before doing more.
One side.
2nd side.
All done!
Now to start attaching the rads. 2 done
All 3 attached! Looks great
Here are the threaded Koolance quick disconnects that I'm using.
Next I installed all the fans to the backs of the rads.
Then the tubing. I'm using Koolance rotary 90 degree fittings, Bitspower 1/2" barbs and 7/16" tubing.
Next I made a ~5' long power cable for the fans. I just threw on some old cheap black sleeving to keep the wires neat.
Lastly, I leak tested the system for a few hours. No leaks so I guess its good!
I'm pretty sure I'm going to carbon fiber the black. Its shiny and shows dirt and fingerprints and I don't like that. I need to order some today.
Until next time,
Fuga
Not a big update. Got the fan filters in and I'm still waiting on the 3M Carbon Fiber to arrive.
Got them all installed.
As soon as the Carbon Fiber arrives I'll be done with this.
Cheers till then,
Fuga
Ya fans are on backwards right now. Everything has to come off when I wrap the whole thing in carbon fiber. I switch them around then. I just wanted to see what it would look like.
Couple questions...
1) What are you going to cool with this setup?
2) Where did you pickup the fan controllers/fan headers?
Lastly, looking good and keep up the good work.
Looks great bud, keep up the good work!
Thanks!
Couple questions...
1) I will probably hook it up to my folding rig. See my other project thread :D
2) Got them at PPCs. 2/5 were bad but that was expected for a $1 product. Can't find the link right now.
And thanks :D
How did you decide how to route the water flow?
In one side of the rad, out the other. When I was using tubing I just went the easiest way to route the tubing.
I am currently testing using some BP Crystal Links. No leaks so thats good. I still have to order another one for between the other 2 rads. And I have to figure out how to route the tubing out of the rad stand.
I made the [H] front page!
http://www.hardocp.com/news/2012/07/18/diy_radiator_stand
I did a few things.
Installed a BP crystal Link (smallest one) between 2 of the rads to elimate the tubing.
Then I leak tested for about 14 hours. No leaks so its a win! I ordered some more SLI fittings so I can do it between the other 2 rads.
This is ugly and restrictive!!
I need to find a way to hook the rads up to the inlet in an effective way. I can't really use tubing (ideal) because of the angle. So I came up with this solution.
D-Plug, 50mm extension, 90 degree crystal fitting and a SLI fitting I had laying around. Its easy to take appart and looks way better.
Next I installed a pump on the side to help out. I had an extra DDC3.25 and an EK top so it works way better than the stock top. I'm thinking of putting dual pumps on this with a heatkiller pump top but I have not decided yet. Need to do some testing first.
Here is how the tubing looks right now. The loop is where the next BP SLI fitting will go.
I'm gonna work on connecting the pump to the fan bus since its all 12V. I'll have another update tomorrow assuming I get some stuff in the mail today.
Cheers till then,
Fuga
Very nice. So is it cheaper to build your own rather then buying the pre-made stand?
Its barely cheaper. Materials and laser cutting cost me about $70 where the pre-made one is about $100 shipped. I just like mine better because I did it and it looks exactly they way I want it to.
Time to finish up!!
Got my Carbon Fiber!
I took off all the rad grills.
All done. (No mid way progress pics because this was very time consuming.
I also added CF to hide the fan labels.
I got the last SLI fittings that I needed. so Now the connections look super clean.
Then I decided to add a res to the build so that the pump would never run dry.
For some reason this setup didn't feed the pump enough so I changed it up. Lucklly I have lots of extra fittings now a days.
The carbon fiber looks really nice.
I post final photos soon.
Cheers till then,
Fuga
That is totally BAMF.
Now you just need to sleeve all those wires. And remove that swiftech sticker from your pump.
Final Specs:
  • 3x Swiftech MCR320 (360mm) Radiator
  • 18x Yate Loon High Speed Fans
  • Swiftech DDC 355
  • EK-Multioption 150 Reservoir
  • Koolance VL3N Quick Disconnects
Final Weight with water: 20 lbs
Final Photos:
A special thanks goes out to Thomas Harrell of White Light Laser who came up with the design for the radiator grills and also who cut them for me. You can visit his Etsy shop here.
I hope you all enjoyed this project. I know I did.
Cheers till the next mod,
Fuga
Nicely done! Does the pump power your loop in whatever you attach this to as well, or is that a supplemental pump just to push water through the radiator stand?
Wow I just noticed these comments... Sorry guys.
Wow. Fantastic build.
Thanks
There are 3 pumps already inside the case. The one on the stand is just to help out but I can hook this stand up to any other system and it should do fine. Might need to have 1 other pump inside though.
Probably not but that sure looks fun. Nice job!
Was a very fun project and I reccomend it to everyone!
