istgt[3440]:istgt_iscsi.c:4328:istgt_iscsi_send_nopin: ***ERROR*** before Full Feature
istgt[3440]: istgt_iscsi.c:4817:worker: ***ERROR*** iscsi_send_nopin() failed
Does anyone know a good way to build your own iSCSI for learning with windows server and ESXi?
Easiest way to set up an iSCSI target is Solaris Express 11 / OpenIndiana + nappit. You can run it as a stand-alone or under VMware.
Load SE11/Openindiana, load nappit, setup COMSTAR from the nappit menus. Done. 100% free with OpenIndiana, still free with SE11 as long as you don't meet Oracle's definition of "production use".
See here for simple steps to load SE11 / nappit under vmware: http://www.napp-it.org/doc/downloads/all-in-one.pdf
I don't see much sense in experimental environment running target under Windows. What for?
You cannot do anything with one connection access. Cannot do VMotion. Cannot do HA. What use in such a software? Marketing only? LOL
Running target inside two ESX nodes to feed storage to each other is possible but it's not a beginners task in any case.
P.S. And cake support forum is very impressiveI did not see so many "buy viagra" links in the single place. Compare with say openfiler.com community status to see the difference.
He didn't specify an OS requirement, so was just trying to give a quick overview of what was out there. Wasn't trying to start a pissing contest over which was better(COMSTAR was my recommendation anyway - at least that's what I'm using, can't say I've tried any of the others packages other than Windows Storage Server 2k8).
Don't like people calling me a bitch but... OP referenced "windows" and "ESX" in his very first post)))
Olga
