DIY Case Fan Hijinks
Man it up, and be the mod. And figure out if you want/need grills or filters at any fans you put in, if it'd conflict with what usually belongs in the area, ect.
Agreed; get a dremel and some testicles. :D And remember; ducted fans > non-ducted fans.
You DO realize that, having posted, you now owe us pics, right?
well, I guess people are gonna be pushing for you to do some cutting. :p
Anyway, what exactly do you wanna do? Where do you plan on putting some bigger fans and how many? I don't know how much bigger you can go on that rear exhaust without things being messy. It looks like a 92 would be cozy there, and you're generally gonna want more exhaust than intake.
There will be pics, I promise you.
Also, I've decided that I'm gonna do BOTH slot-mount and standard case fans. I can drill and holesaw where needed, use grills, bolts, etc. and as long as I have open power connectors I'll keep adding fans.
What about filters? Do any of you guys have any experience with air filtering setups?
