CaptNumbNutz
- Apr 11, 2007
I have an anti-static wristband, and use it religously since my apartment is completely carpeted and I have zapped a video card before. Since I started using it, I have not had any ESD zapped gear. *knocks on wood*
I have a couple problems with it, and I haven't found a decent replacement at any of my local shops.
Problem #1
The strap is too short, and its curled so it has a sort of tension in it, like a telephone handset cord.
Problem #2
Finding a decent place to clip it onto. The alligator clip on it doesn't grip too well. Combine this with the other problem above, and it comes unclipped easily.
Can I extend the wire by splicing a longer wire too it?
It would be soldered and heatshrinked of course.
Instead of using the alligator clip, can I solder the wire to the ground wire of a spare 3 prong AC power cord?
The other two wires would be removed and their respective plugs insulated...
I could plug it in and leave it, and with the longer wire, have a larger range of motion.
Modifying my current one would be cheaper than buying a new one, and give me these features I need.
Problem #1
Problem #2
