DIY Ait filters
laserbeam
Hi All,
I'm due to take delivery of the components for installation into my new Lian-Li 6070B case. Dealing with dust is something I'm just starting to consider. Has anyone tried making their own air filters? If so, can anyone recommend the best material to use,ie. not so dense as to dramatcially impede airflow but substantial enough to capture dust et al.
Thanks in advance :)
D
http://www.airclean.com/
These filters, Ultra S & Ultra SW in the order colum of link are electrostatic media I use them. You can cut to fit.They have low static so air flow is good. The other models are very good for whole house filters also i have used these for years and get positive feedback from customers.
That's good but I live in the UK. Should have made that clear initially, sorry ;)
Thanks,
D
Panty hose from the dollar store...or pick up a chick wearing panty hose, take her home and do the "deed", keep her panty hose as a souvenir...
MD
Pantyhose or those air filters used in air purifiers..
