HardOCP News
[H] News
- Dec 31, 1969
Want to know how to build an 8x8x8 3D LED cube? Well, you are in luck because Instructables has a guide and video of the finished product.
I'm guessing each LED needs to be powered individually in order for only one in any particular row to be on off, so at 512 LEDs, at 30mA each (again guessing they're 5mm LEDs), that thing could potentially pull over 15 amps at a time.
Who cares about the cube, I'm digging that song!
It's called Homeless - EP, just got it off iTunes.![]()
How much would building one of these cost?
512 of them!That's a bangload of LEDs.
Yeah, in the YT link, the guy listed the following:Who cares about the cube, I'm digging that song!
They're using matrixing to save on I/O ports, so they probably are pulling less current too.
Looking through the instructable, they've got it so only one horizontal layer is on at a time. But they switch so fast, you can't tell. This is a pretty common technique. It's hard to find a microcontroller with 512 output pins, but by using the matrix they've setup, they only need 64 pins for the horizontal plane and 8 pins to switch the vertical axis (total 72 output pins). If they split each horizontal layer in half, they'd only need 32 pins for each half plane, and 16 to switch between them, so 48 output pins (could save a few more if you do a 23 x 23, but output ports tend to come in multiples of 8 and it's not worth it to save 2 pins), but they have to switch faster to get the persistence of vision effect.
