- Sep 7, 2004
Finally decided to jump into a custom loop build for my rig (see sig). I am looking to cool my 2600x on a Asrock Taichi x470, and 2 GTX Titan Xp graphics cards. I did use the EKWB Configurator but I did notice that it lacks an option to add a drain port, what parts do I need to add this to the rig? I already have plenty of Corsair ML120 fans (5 of them)
EKWB G 1/4" EK-FC Terminal Dual Parallel 3-Slot Graphics Water Block - Black
PrimoChill PrimoFlex 3/8" (10 mm) x 1/2" (13 mm) Advanced LRT Tubing 10 ft. - Crystal Clear
EKWB G 1/4" Straight Compression Fitting - Nickel x10
EKWB CryoFuel Pre-Mixed Coolant 900 ml - Clear
EKWB ATX Bridging Plug 24-pin
EK-CoolStream PE 360 (Dual)
EK-CoolStream PE 240 (Dual)
EKWB EK-FC GTX 1080 Ti Water Block - Nickel x2
EKWB EK-FC1080 GTX Ti Backplate - Nickel x2
EK EK-Supremacy EVO RGB AMD Water Block - Nickel
EK EK-XRES 140 Revo D5 RGB PWM Reservoir with Pump
Here's a link to the parts I have in my cart, I am looking to source the parts from my local MicroCenter.
