Divider setting in P4C800-E Deluxe
Ou7k4st
I have been trying to get my 2.53 northwood stable @ 3 with a 160 FSB. It doesn't seem to be able to do it(its fine @ 2.8), but i can't find the divider setting in this bios? Anyone else use it?
Also if i try to set the vcore manually at all i get no boot :confused:
400 = 1:1
320 = 5:4
266 = 3:2
I'm not sure about the other ones since it's such a waste using a 533FSB P4 on a P4C.
It doesn't have the divider option. It just asks what speed you want to run it at, ie.. 400/333/266.
