Hey all,
I wanted to lay out some thoughts/theories/plans here since this forum sounded appropriate. I would like some opinions. I have a lot of thoughts, but bear with me, please...
The Details:
* I have some old spare systems; probably 150 to 200. Most are homogeneous Compaq Pentium III 933MHz systems. I also have a lot of homogeneous IBM NetVista P3 800 and 933MHz systems. They are still at my parents house doing nothing. They are complete systems; onboard Intel video, 128 to 256MB PC100/133, 10 - 40GB HDs, with CD-ROM drive. I think these would suit well for setting up each as a BOINC, or F@H client under Fedora. They may not be the fastest things, but they would compute for science/health/astronomy and that's all I'm concerned about.
I have also tinkered with the idea of setting up a Linux cluster using OSCAR or similar.
Setting up the computers won't be a problem at all.
* I would like to keep each BOINC "cluster" (set of machines) and Linux cluster behind a VLAN or router to keep any broadcast traffic to a minimum. Making another router out of one of the non-homogeneous systems is not a problem (IPCop, BrazilFW, etc.)
* I also have spools of unterminated fiber that I can use to run underground to the building to the basement for uplink to my primary network in the house. Not to every system, but more of a "long-haul" connection. I just have to get someone to dig the ditch and terminate the ends.
* I should be getting a home soon now that I can support myself with a full-time job. The home I am hoping to put a bid on has a nice basement and a separate large RV/semi-garage a few hundred feet down the driveway. As soon as I get the place, I plan to move all my systems out and into the new home.
The Obstacles:
1. Power - no real explanation needed for this one. Lots of computers will require lots of power. I'm not sure how to get around this. I've thought of solar, but that is a large investment to begin with for not that great of conversion efficiency. Then you have to concern yourself with cloudy days, batteries, and keeping the systems up at night. I've also considered wind, but the area I'm in doesn't have a lot of wind. The only other "alternative" energy I can think of getting diesel generators and converting them to biodiesel/vegetable oil. I'm aiming to do it as green as possible no matter what energy source I use (grid, solar, bio). Note that the primary objective here is to compute for science, astronomy, health, and climate change.
2. Heat - All those systems will produce heat. I can modify the building to have fans near the top of the wall, exhausting the heat that rises to the top. I've also thought of adding other fans at the top of the opposite wall to intake "cool" air. Air conditioning would be out of the question unless it was very cost effective and/or cost less to cool versus fans.
3. Time - I'm a full-time tech at a large corporation and part time college student. During the semester I don't have much time to devote to much other than classwork. My job is awesome, but I can't take off work suddenly if half of one of my clusters dies.
4. Money - Even though it might sound like I have a lot of spare cash, I don't really.
Why, you might ask?
Well, mainly, doing exactly this has been one of my goals for a long time now. I've wanted to find a way to put my computers and technical skills to use for science, health, astronomy, and the environment, even if it's just crunching numbers using the BOINC platform.
I plan to try to do this starting out small and build from there (testing the waters), whether it's completely ridiculous or not.
As mentioned, I had hoped to do it in a "green" way, to help out the environment as well. Speaking of which, I've gone as far as developing a small website laying out my thoughts and ideas to the public. The site is: www.greenpowerdatacenter.org
Unfortunately I have not got many hits on the site as I am unsure where to advertise.
I'm not trying to advertise my site here, but get it out there and also ask you guys if there is an appropriate place I could advertise it, or you knew of someone willing to advertise it.
I would like your thoughts on feasibility, advertising, project support, or anything else you would like to add.
Thanks for your time! Smile
The Details:
The Obstacles:
Why, you might ask?
