Hello!
So, I think I'm ready to try my hand at putting together a custom loop. I've used AICs in the past, and while they're great and all, I want to do something different.
My goal isn't to put together anything extreme; I just want a simple loop that is relatively easy to maintain and does a decent job at keeping things in check while keeping system noise to a minimum. I have a basic idea of what I need to buy and how to put all of the pieces together effectively, but I have been left with a question that I can't seem to find a straight answer on: can I get away with using a single 2x120 radiator to cool a loop consisting of my processor and GPU.
The processor and video card in my rig only have mild overclocks, and the load temps are very reasonable using air (70C for the processor w/ Prime 95, 60C for the GPU w/ Furmark). Both still have their respective power-saving features enabled.
Anyway, any input would be greatly appreciated. Here is a spreadsheet of my parts list for you all to pick apart. I'm pretty firm on the blocks and res/pump, but anything else can be changed.
Thanks!
Thanks!
