Yields that low are simply not possible to sustain.
I think it's pretty clear to all that defect ratio is inversely proportional to yield... The more defects the lower the yield, then taking into consideration die size it's clear that is directly proportional to yield. The larger the die at a given defect ratio, the lower the yield. This is common sense, but a defect ratio that high would require an unsustainably low yield, and I dont buy it. It's BS.
Like I said from the very beginning it assumes a ridiculous defect ratio. And I dont buy that number.
Here you ago yet again with this circular illogic. As I have stated numerous times and you ignore each time. There is a simple fact of the semiconductor industry:
Defect rate decreases as a process matures.
One more fact:
Intel has a much more mature 65nm process as they have been producing much longer.
Therefore:
Intel will have a lower defect rate.
Now in your absolutely twisted unreasoning, AMD can't have a higher defect rate because it would be terrible for AMD!?! This has got to be the most transparently faulty thinking you exhibit. Just because you don't like the outcome of facts, you can't work backwards and insist that the facts must change. I think this is known as insanity.
Now combine Intels lower defect rate with smaller die size Intel will have a much higher yield rate. Certainly we don't know the numbers. But this is a big part of the reason Intel makes tons of money and AMD loses it. That and Intel commands higher ASP. Lower yields and lower ASP is the recipe to lose hundreds of millions of dollars.
Just like you knew that P4 was going to be the greatest thing since sliced bread, and that Itanium was going to revolutionize the industry... Only people with your level of know how knew that.
No that is because unlike you, most of us are not blind rabid fanboys. I knew the P4 sucked that is why I used Athlons and never owned one. When the K8 architecture was first shown, it is why I said it would kick Intels ass and faced rabid Intel fanboys just like you are a rabid AMD fanboy. I just like the best tech, so I get attacked by fanboys on both sides.
I am knocked off my feet with a nasty virus this weekend. What is your excuse for blowing your weekend in front of the computer inviting people to attack you by saying ridiculous, irrational things?
