Just upgraded to an HIS 4890. Using the 9.6 catalyst alot of the options easily available in nvidia's control panel are no-where to be found or are stupid hard to find. Using windows 7 RC.
First thing that I would consider a simple feature is resolution, I can't change the resolution of either of my displays through the CCC. I have to use windows to change resolutions.
My 1080p HDTV's maximum resolution through CCC is 720p, whereas I could use 1080p without issues with my nvidia control panel.
No stretching of the desktop across multiple displays. You can "extend" the desktop but not have a single desktop displaying across multiple monitors. (Need this for Left 4 Dead Split-screen) ATI Hydravision does nothing, although it has the option to stretch the desktop like I am trying to acheive it doesn't actually work. I did this regularly with nvidia's control panel.
ATI Overdrive doesn't work. All options are grey out. I do have both PCI-e power connections connected to the card (not sure if this is required or not, I just remember some older ATI's had 2 connectors and would only overclock with both occupied)
Also can't find anywhere to set custom resolutions, and gpu scaling is greyed out.
What gives? The card performs awesome but so far these drivers/catalyst are a horrible joke compared to nvidia's.
Please don't post and accuse me of trolling, I'm simply asking for help in finding how to access/enable these options for my 4890.
