displays
i am wanting to do surround with 3 monitors thinking 30 inch also Korean monitors 2560 x 1440, but do u have to buy monitors that pivot to run 3 monitors in virtical mode or can i just change the screen angel. Also if anybody has any other monitor options and sizes would like it also slim bezel would be the best
You can do any type of surround setup you want.. as long as they are the same resolution (and preferably the same model and panel type as well). 3x korean panels would be a great setup for most gaming scenarios, as they're cheap for the pixel density, and they have great viewing angles.
You can always buy a third party triple screen mount if you want to run them all in portrait, That will probably look best as well.
honestly I think 3 x 30" is massive man, and you'll need HEAVY graphics power to push those puppies. Perhaps a 24" x 3 or at most a 27" x 3 setup would be much easier on the graphics card while still providing a fairly massive resolution.
