I want to run eyefinity on 3x 1920x1200 with an sapphire 280x card. And realized I have to buy an active display port -> DVI adapter to run 3 screens. I have some questions about the adapters:
The only branded one I found within reachable distance is: http://products.xfxforce.com/en-gb/Accessories/Display_Port/MA-AP01-PD1K this, anyone have experience with that?
- Will this adapters lower the image quality, cause blur, or add input lag?
- I found some older (2010-2011) topics about flickering issues and black screens, are they fixed by now?
- I'm intend to use it in 1920x1200 resolution, so a single link would be enough. Should I buy an usb powered dual link for better image quality? (tho this question is moot if it doesn't change quality)
- Are there any recommended brands?
- Does the brand actually matters?
