I am not sure if it is the monitor or videocard causing this problem, and I am wondering if anyone else has had this problem with this monitor and how to fix it. It randomly came on, and its been working flawlessly for 2 years. The monitor is a
NEC/MITSUBISHI FE991SB-BK 19", and the videocard is a Radeon 9700 PRO. Every once in awhile the top and the bottom of the screen sorta pinches in about an inch down on both sides it turns light and almost has a bent look. Please help, when I get back I'll hook up the monitor to another computer, but before that I want to know if that is a common problem with either the card or the monitor. The videocard was replaced ~4 months ago because the other one had a bad pin holding the heatsink in, and it constantly was falling off.
