display problem
Gryfalcon
Hey guys think this is the right thread to put this in. I have a problem I just bought one of the ceton InfiniTV 4 cards. Had it working flawlessly for a day then suddenly it started giving me a error in windows media center. It started saying in Media center "Display driver error: the video playback device does not support playback of protected content." I am running this on a radeon 6970 which is hdcp compliant to 3 asus 24" monitors via 2 of them with DVI and 1 with display port cables. Sometimes it aslo gives me a "HDCP support required" error. anyone know whats causing this? I am running it all on a Gigabyte GA-790FXTA-ud5 board with a amd phenom II 965 Black proc.
Does it happen with any channel you are looking at, or only certain channels?
I was looking to get the same card you are using, seems like a great card (if it works correctly).
p.s, bloody stupid DRM :mad: They only hurt the paying customer by doing this crap.
Got it to work had to move the screen to the monitor on the display port cable. Move it to the ones using DVI and it wont work. Think if you use the display port or HDMI it will work fine. Thought DVI cables were capable of carrying HDCP content.
