Display Port or hdmi to DVI-d
zetachi
Quick question. Looking to upgrade my 1070 to either a 2060 super or 5700xt. I see most of them come with 1 HDMI and 3 or 4 DP. My issue is my two monitors. Main is a 27" Xstar with DVI only and the 2nd is an old ASUS 27" 1920 x1200 with HDMI and DVI. I think i'm safe with a DP to DVI adapter and then HDMI for the 2nd but just wanted to confirm before buying.
Thanks
I'm using two Asus VE247 monitors with dvi/hdmi output. I bought a pack of dvi to dp adapters to hook them to my 2080 super. I have two left sitting in the closet I need to make disappear. My primary monitor is a viewsonic 2401 and uses dp with no adapters.
Thanks
You're going to need dual-link DVi active adapter for that Korean XStar.
You knew the dead-end you were buying into when you bough it seven years ago.
It comes down to what resolution you are going for. If 1920x1200 (@60hz) or less is all you need, then single-link DVI output is fine. Then you can use a passive HDMI to DVI adapter or a relatively simple DP to HDMI/DVI adapter. Single-link DVI has a max of 1920x1200 60hz. If you need more than that on DVI, then you need dual-link DVI. That means an expensive and quirky active adapter. OR, you can simply run your monitor using single-link DVI, which would mean running at 1080P instead of it's max resolution. You might even be able to manage 1440P at something like 30hz depending on the monitor.
The cost have finally come down, do why bother futzing around with custom resolutions?
https://www.amazon.com/3D-CAC-1010-...NMTNK21H87X&psc=1&refRID=E23R3N7ERNMTNK21H87X
Yeah the xstar is 2560x1440 60hz so it looks like gpu with 2 hdmi ports or a $50 adapter or a new monitor.
Thanks all.
It's nice that they don't cost hundreds of dollars anymore, but spending ~$50 on such an old monitor would still be a tough pill to swallow.
Because it doesn't cost any money.
Also, active adapters are REALLY flaky and quirky. Better on Nvidia (different clock sources, IIRC) than on AMD, but quirky either way. I bought new monitors to get away from them finally.
Monoprice sells an adapter that works at 1440p for a whopping $13.xx
Back again. So I found a GPU that has 2x HDMI 2.0b outputs. Is this still the same issue if wanting to run 1440P @60hz to DVI-d. Trying to find some definitive answers and the google searches are all a mess of conflicting information.
