Display Port Cable - Shorting out the card/mobo?
Discussion in 'Video Cards' started by Sean, Sep 25, 2012.
  1. Sean
    Sean [H] for Life
    5,285
    Nov 16, 2000
    I just found that my DisplayPort cable has been shorting out my video card and board. Anyone else have something like this happen?
  2. XTF
    XTF Gawd
    591
    Oct 11, 2011
    Why do you think it did?
  3. Kamainae
    Kamainae [H]Lite
    72
    May 3, 2009
    Check for continuity on the pin 20
    [​IMG]
    If it is connected, thats the cause, I had to get rid of them on two of my cables, you can use a pair of tiny plyers or tweezers to pul the pin.
    Good luck.
  4. CompMage
    CompMage Gawd
    851
    Sep 7, 2003
    Personally I've done everything I can to stop using DP. The cables tend to be really flimsy, have a hard time holding in and I've had 2 of them rip them self apart completely.
