The Matrix
- Mar 3, 2008
Hello guys.
I seek your advice on two things, a) about an error that I encounter after running an extended hardware diagnosis (error code = 4HDD/11/40000004: SATA (0,0)) and b) if it really makes sense to invest in Diskwarrior (as it costs nearly $100)
To give you the big picture, lately the performance of my mid-2009 MBP deteriorated. And the first thing I did was run an extended hardware test to identify potential issues. And indeed I encountered the error message "4HDD/11/40000004: SATA (0,0)"
I immediately took it to the genius bar and the technician there ran his own "apple" certified diagnosis and stated that its not really a hardware, but seemingly a software issue. And I was suggested to do a clean install of Mountain Lion, since the technician suspected that an upgrade from Lion -> Mountain Lion may have caused some directory conflicts.
Well, I did manage to do a clean install by first erasing the HDD, installing ML from scratch and then re-storing the last back-up image from Time-machine. At least this is how the clean install was suggested by this technician.
Anyhow. The performace seems to be better, but I still encounter the same error
I went back to Genius bar and the guy said "if you really have problems when working with your MBP, then we could envisage replacing your HDD" But he insisted that its an expensive affair and not required as per the diagnosis done by "apple" certified tools.
Hmmm
So am really wondering if I should invest in Diskwarrior which could perhaps find a cure for this error code?
If you are wondering "what issue(s) am facing exactly" - Well, a silly issue I must say. Everytime I try to drag and drop files between drives or applications, it gets locked ! Meaning, I can drag, but not drop and it stays that way unless I reboot the laptop. Its really an annoying issue :-/
Please bare with me if missed being precise on some aspects.......
Your views / feedback will be highly appreciated.
Thanks a lot !
Hmmm
Thanks a lot !
