Hi,
in order to fix my RAID-5 problem, I removed the offending drive from my server, which requires a shutdown, open case...
The drive turned out faulty... but that is for another thread.
I decided that I would need to reboot the machine, since I cannot work without my DC online for the next two weeks. The PC (Dell SC420) boots of a 80GB Maxtor HDD and the RAID-array is connected through a Promise SX4-M card. The Maxtor HDD connects to the SATA-0 port on the onboard controller.
Upon rebooting, I saw a flashy warning for "RAID degraded..." and decided to skip the rebuild (do not have a drive on hand atm). The PC would not boot the OS, but told me that there was a drive read error and asked me to CTRL+ALT+DEL to reboot.
After this happened a couple of times, I opened the case, took out the RAID-card, checked the cables on the remaining HDD (disconnected power from the others) and still got the same error message.
After transferring the HDD to my other Machine (thank god for SATA hot-plug) it shows up in the device manager and drive management tools. The drive management claims that the primary partition on it does not have a filesystem and that the drive is empty.
I am now open for suggestions on how to proceed smartly in order not to destroy my windows install on the HDD.
What tools should I run in which order? What could be broken and how can I repair it? I am sure that I will need to replace this HDD soon, but it'd be nice if I got my Win2K3 install off it first.
