So I recently had to upgrade my mobo, proc, and graphics card (and RMAed my PSU) recently for various reasons not worth getting into here. So I bought a MSI K8N Neo4 Platinum, Athlon 64 X2 4200+, and a PowerColor X800XL 256MB. After finding the necessary drivers, I decided to give XP x64 a try. But for the life of me, I can't get it to install.
What happens is such. I boot off the x64 CD (burned from ISO) into the install program. Go through the prompts. I install the OS on the primary partition of my Raptor 74GB. It formats, installs, and restarts. On restart, I get the following message.
Here's what I've tried to remedy the problem so far.
At this point, I am beyond stumped. I searched on Google for people with a similar problem as well as the [H], but couldn't find anything that addressed my issue and proposed a working solution. I understand that I could just install 32-bit XP, but at this point, I've become determined to defeat the error message of doom. Oh yeah, it's definitely a software message because if I change the hard disk boot order, I get the all caps NO SYSTEM DISK FOUND OMG DOOM WILL ENSUE!!! or something like that. Any insight or assistance would be immensely appreciated.
A disk read error occurred.
Press Ctrl+Alt+Del to restart.
- Checked to make sure it wasn't hardware by installing XP 32-bit. Worked without a problem.
- Tried installing on a partition that spanned the whole drive. No dice.
- Tried using the recovery console. Ran BOOTPART, FIXBOOT, FIXMBR, MAP, etc. Also didn't work.
- I tried a different burned CD from a friend that successfully installed XP x64 in case it was a disc error. That one didn't work either.
- Ran CHKDSK /R on the Raptor. It said it found and fixed errors, but the problem remains.
- Tried loading the x64 version of the SATA drivers on a floppy and hitting F6 when prompted. Also didn't take care of the problem.
