Disk drive ejects on boot
So far it only happens to my 2 year old cd-rw drive and never to my 1 year old dvd-rw/cd-rw combo drive. I tried swapping IDE cables and using 2 different IDE ports on my mobo, and it still happens whenever I boot my system.
I haven't tried using a different motherboard since I don't have one available. It's been happening even after I updated my bios twice to the current version number's beta and final and since I swapped from xp to vista and back to xp again. I guess that effectively eliminates software as the culprit.
I suspect it's most likely that my disk drive is crapping out with age, but I could very well be wrong.
Reload the firmware on the drive? Is there an eject button on your keyboard?
By reloading firmware do you mean update it? If so, my samsung ts h292b doesn't provide any kind of support for software updates. I don't have an eject button on my keyboard.
If reloading or updating the firmware doesnt fix it, I'm guessing the drive's on its way out. I had a DVD-ROM that would just open and close randomly before (like 10 yrs ago or so), lol.
