D1sc1pl3 0f Mal1c3
- Sep 19, 2004
Ok, so I've finally decided I needed to upgrade from my old IDE hard drive, so I bought this HD from newegg:
(http://www.newegg.com/product/product.aspx?Item=N82E16822144701)
and this cable to go with it:
(http://www.newegg.com/product/product.aspx?item=N82E16812226004)
This is my motherboard:
(http://www.newegg.com/product/product.aspx?Item=N82E16813128056)
I plugged the SATA cable I got into the HD, and inserted the other end of the cable into one the SATA ports on my mobo and the power connector into another open power line. I try and boot up, and I get this "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER." I know there's nothing wrong with my actual OS CDs, since I'd just used them earlier. I've never had any issues with installing IDE drives before, and I've never done this, so can anyone look at my hardware links and tell me if something doesn't mesh, or if I'm not installing it correctly or what . The SATA Controller is enabled in my BIOS, and the only other option I have is SATA Type, which is currently set to Native IDE (other options being RAID, Legacy IDE, and SATA ->AHCI). I even tried using the SATA cable that came with my motherboard, so the cables aren't an issue.
