Discount system or full out?
Svetgar
Finally going to be building an actual system instead of just using my laptop.
Picking parts is easy enough, but I'm getting hung up on whether or not I should be building a discount system (X6 1055) or a full out i7 2600k.
Now, I will probably not be upgrading again for about 4 years or so. Lets put it like this, the system I retired is a A64 x2. So I keep stuff for a while. I mostly use it to play WoW or Rift, or other games and browsing the net. I would like to start ripping movies though, if that will make a difference.
So I'm torn. On one hand the value of the x6 is hard to ignore, but its old. I keep stuff for a while, so no reason to skimp, right? But I still hesitate at the $315 cost of the i7.
Also, I don't know what the current best deal is for video cards. I don't feel comfortable spending more than $200 on one. Another issue of mine is that I am big on quiet systems. I do not like computers I can hear running from my desk. So whatever card I get has to have a reasonably quiet fan on it. I have used the Sapphire vapor-x 5750 on my wifes system with much success. So something like that is what I'm looking for, though i don't care about ATI vs Nvidia.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
gaming, video, net
under $600, all included
3) Where do you live?
USA, no microcenter, but can get to frys
CPU, mobo, ram, video card, blu ray drive, cpu cooler
monitor, kb, mouse, case, SeaSonic S12II 620
6) Will you be overclocking?
sure, but its not a hobby or something I will obsess over as long as it doesnt increase system noise or heat excessively
1900x1280
this weekend or so
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
sata, I dont bother with xfire/sli. usb 3 would be nice for future proofing
yes, win 7 64
$600 for the complete system throws out both the i7-2600K and the X6 1055T. Besides, currently, you don't need Hyper Threading or six physical CPU cores for gaming.
Do you really need a Blu-ray drive? That's another expense that you may need to omit, as oftentimes you not only have to buy the drive but also the Blu-ray playback software. (Many OEM models only come with the drive.)
It would help us immensely if you were to tell us which specific parts (brands and model names/numbers) you're reusing. The SeaSonic S12II 620 is a good PSU, but how old is it? Also, which games do you plan on playing on this system?
I have built a number of systems over the years (6), and I suggest you build
ahead. Yes, it cost more for top of the line, but you can get by with
small incremental upgrades that keep you close to current.
In doing so, I only build new, about every 4 - 5 years.
The guys here, can give you kick ass recommendations , they know there stuff.
