Disassemble water cooling kit?
Changwang
Hi
I am just wondering, how do you efficiently disassemable an already installed water cooling kit without getting water in the tubing all over the place? I use a reservoir. Is there a way to empty all the water into the reservoir?
Thanks
dump the water out of the reservoir and then run the pump for a few seconds till the water fills reservoir up again then dump it and keep doing it.
I think that will work i dont know i dont have water cooling.
yah except it will damage alot of pumps if you run them dry.
Changwang said:
Hi
Thanks
I usually remove all the computer components first. that way it doesn't matter if i make a mess.
