I was on my machine yesterday and happened to look at my NVMonitor screen at my case temps and noticed my gpu temp had dropped off. It had just happened w/in the past 30 minutes or so because I saw the line that was graphed before it cutoff. When I went into settings, the gpu sensor option was greyed out. I restarted my pc a couple of times, but no go. Is it common for a sensor to go bad or did something come loose? My board is a dfi ultra-d and I built the system about 3 months ago. The card is working fine and the case temps are still good--just missing the gpu one.
Thanks!
Thanks!
