Hello! I just finished putting together my first watercooling system and after testing it, I am very disapointed with the performance. Here are the parts:
Danger Den TDX CPU block
Danger Den nv-68 Rev. 1 GPU block
Danger Den DD12V-D5 Pump
Dual 5 1/4" Bay reservoir
Black Ice Xtreme 3
3x Evercool 120mm aluminum fans pulling from the BIX3
1/2" Tygon Tubing
I am cooling
1x Athlon FX-53 940 socket
1x 6800 Ultra
Idle, my temps are:
CPU: ~33C
GPU: ~60C
Load my temps at the highest are:
CPU: 36C
GPU: 89C
I am fine with my CPU temps but my GPU temps I think are a bit high. 60C Idle is about what I had before on my stock cooler. The funny part is, the moment I take it out of load, it goes back down to ~60C in 2 seconds. Could it be that its not mounted correctly?
I know the water has good flow because there is a lot of turbulence in the reservoir. Controlled turbulence though so there are no bubbles as a result. I know there are no bubbles in the system.
I am using Arctic Silver for the GPU and surrounding ram. The coolant am using is a 90% Distilled water 10% Zerex anti-freeze/coolant mixture.
The loop goes pump -> GPU -> CPU -> Radiator -> Reservoir. The radiator is mounted outside the case on the side.
I do not know what I am doing wrong! I have no L bends, I have nothing bad that I can see, what is wrong?! Maybe I should have the fans push air through the radiator? Maybe I did a bad thermal paste job?
Please! Any help is really appreciated!
Black Ice Xtreme 3
1/2" Tygon Tubing
I am cooling
1x 6800 Ultra
Idle, my temps are:
CPU: ~33C
GPU: ~60C
CPU: 36C
GPU: 89C
