Just be sure that you do a Windows update, also if you are not gonig to use IIS stop the service from starting. If you are giong to be using it be sure to keep it patched.
I doubt I'll really be using it, but I wanted to have the option to program for web services if I need to. If I'm not programing for web services then it won't be used.
