Disabling PAT on IC7-MAX3 - is it possible??
Spree
Hi
Is this possible? All I have in the bios is the Game Accelerator Technology (GAT) settings. Disabling what I can there (having settings of auto-auto-auto-disabled-disabled) still leaves PAT enabled.
Is there anything I can do to disable PAT on this board?
Thanks
Why would you want to disable it? An IC7-G has an 875 chipset, which inherrently has PAT built-in. An 865 would be a different story.
Coz I want to see if its holding me back on this 2.8C. The guy I bought it off had it at 3.4Ghz on stock voltage. I can't get it stable at even 3.3Ghz no matter how much voltage I give it. From his experience he suggested that PAT held back OCs of the same chip on IC7 boards compared to other boards.
First of all, setting GA to Auto is only rumored to disable PAT. If you ask me, I doubt it. It doesn't make much sense. What makes more sense is to use a CPU:Memory ratio other than 1:1, which is also rumored to disable PAT. But, what I don't get is what will you do if are ever able to get to 3.4Ghz? I suppose you would pop a cork and have a cookie, because you won't do much serious computing with such an aggressive overclock.
Overclocking is like drag racing. It may be nice to know how fast you can go, but you can't drive to the supermarket that way.
Well it is certainly possible that it's PAT that's holding you back, but maybe not. Some CPU's don't overclock very well on certain motherboards. For example I had a P4C800 and I couldn't get my 2.4C past 2.6GHz. On another board the guy I sold the chip to said that he got all the way to 3.6GHz on air :eek: He also didn't have to hardly touch the voltage to do it. I believe he was using an IC7 MAX 3.
Perhaps it's your memory or another component or setting. 1:1 memory ratio is best. Whenever possible.
Thats gotta hurt. Sitting on a 2.4C gem like that :p . This 2.8C is a bit annoying for me. I have a 2.8E which can do 250+ FSB stable. and that chip uses alot more power (I can tell simply by noting how much higher the 12v rail is under load with the 2.8C). I know my IC7-max3 and ram can push a high FSB, but just not with this northwood which apparently can on other mobos :(
