disabling mouse scroll
bassboy_pete
Hey guys.
I am running windows xp, and i was wondering if there was a way to completly disable the mouse scroll. This is for a work computer, so I don't have any special software, but I do have full access to everything. Is there a registry hack, or anything I can do? Thanks
1) Why would you want to disable mouse scroll??
2) No i dont belive that there is a way to disable it, maybe try some other drivers then the ones XP provides you with
in control panel > mouse i think you could change the wheel to be a useless key like [ and ]. that might help but would not really disable it
