Disabling LEDs on fans ?
Koslov
I just got an Antec 900 PC Case and I simply hate flashy stuff like...blue LEDs eheh. I know there's no switch to turn off the blue LEDs fans so I was wondering how I should proceed to 'snip' them? Pictures would be nice :)
thank you
Yea, look for the led power leads running from the center of the fan, down the struts, and to the perimeter of the fan case. They should be colored differently than the cables that actually power the fan motor. When you cut them, make sure that the loose ends are secured so that they won't fall into the fan.
I did that with 4 of my case fans, because my computer is right next to my bed. It was way too blue, and way too bright.
