Disabling LEDs on an IC7 MAX3
Mcseiam
I have an Abit IC7 MAX3 and I hate the green LEDs around the OTES fan assembly, anyone here disable them? I understand that it is likely something I would have to do in hardware such as cutting a wire or shorting a trace but has anyone done this yet?
Any suggestions? They are driving me crazy - I have decent mod job going and the damn green lights overpower everything....
Thanks for the help in advance ;)
heh, just put a piece of duct tape over it....duct tape can fix ANYTHING!!!!! :D
but seriously, no....i have never tried such a thing...
any way you can take the otes off and either mod the fan or replace it with a non-gay one? maybe you can cut the wires that goto the led's on the fan?
im pretty sure you can take the blue otes bracket off. I also think you can take off the fan because it plugs directly into the mobo.
i just dont think there is any way of turning off those green leds. :(
they annoy me too as my fans are all blue leds but the mobo is green.
Depending on how it is wired, you may not be able to do away with the LEDs.
They may be controlling the voltage to the fan and taking them out may increase the voltage to the fan [which may not be a bad thing, but you would have to totally bypass the LEDs, not just cut one of the leads.] You can test this by just using a wire and jumping the two leads of the LED [you may actually be able to just use the jumper [small piece of bare wire should do.. wrapped around the leads tightly.]
Just some thoughts. I do not own one of these boards, have not tried anything I have mentioned, and take no responsability to your own actions.
Some close-up pictures would be nice to see what we are working with. Where exactly are the LEDs? The pics on Abit site are lacking detail.
reply .. well most leds are not used for voltage regulation simply as notification, but they are surface mount leds so it would require unsoldering them (no easy feat. but better than cutting a trace and the risks involved in it) ) im planning on replacing the leds myself (havent even gotten the balls to look cuz they are tiny and i drink a lot of coffee lol)
second the otes fan can be replaced by virtually any 40mm fan (they used to make 40mm tornado's but i found one place with them ... but they was out of stock and not planning on stocking anymore) oh and fyi i noticed 5c increase in temps across the board when my otes fan failed
if you want to remove the otes completely you may want to pick up some thermal epoxy cuz the amplifier heatsinks are kinda like spring loaded into the otes system and should be reinstalled
Ah.. SMD.
Use a conductive pen to short it out of the circuit. Electricity will always prefer a short over a diode.
I guess voltage regulation was the wrong phrase to use. Was too used to thinking of audio circuits where LEDs were used for regulation. For this case, there should not be any problems. Just meant to mention that every LED will have a voltage drop across it. Red starts around 1.6V, greens are around 2 to 3 volts I think, and blues are usually around 4 or 5Volts. If it is in the direct path to the fan motor, then that is that much less voltage the fan is seeing, so shorting it out will probably be welcome in most cases when it comes to fans.
Thanks for catching me on that, bmxerkrantz
Anyhoo, try the pen.
Thanks for all the help so far
I am not concerned about removing the OTES fan (it is annoying but not too loud) - I really just want the LEDs gone as the color green is not one of my favorites
Keep it coming and I will see what I can do, if I meet with sucess I will be sure to let you all know ;)
Are you sure this is a good idea? I'd expect that the LEDs are in series with a current-limiting resistor. Using the pen to "draw" a short over the LED would put the power supply across the resistor. If the resistor is of a low value,
If the LEDs are in series, then the resistor is going to have a pretty low value.
I've not heard of that. What kind of audio circuts use LEDs for regulation? To regulate voltage, or current?
Why would the LEDs be in series with the fan?
.B ekiM
Maybe covering the LED with a plastic film of the desired color would be another way to correct the problem. I think I've seen cling wrap (used in kitchens to cover bowls) come in various colors - you might try that.
Just black out the LED with a bit of non-conductive paint... (acryllic should work just fine for this) If you put a thin layer on you can even mute or change the color instead of blacking it out.
Or like xXaNaXx said, duct tape, for a slightly less visually appealing, yet no less effective solution.
