Sk8er_Square
- May 21, 2005
I dont have a fix for the incorrect temperature reading on my motherboard for the cpu, so im still going to have consistant problems...Is there a way to DISABLE the cpu overheat protection on the board? Using either software or something, else i cannot find a way around beating the incorrect cpu temperature problems, the BIOS is just completely off and causing the reboots, and asus probe comes up with temps 30-40 degrees celcius cooler.
please help
please help
