rabidz7
- Jul 24, 2014
How can I disable the out of range message that pops up when a Samsung 1080p LCD is overclocked past 77Hz? I understand that this may need firmware hacks.
I believe that needs a pixel clock patcher to remove the 165MHz pixel clock limit, but if the monitor can't do more than 77hz it will probably cause frameskipping at refresh rates above
OMFG!
rabidz7 and LCD thread?
Does not compute...
He did post there, 5 minutes after posting hereRabidz7, you are fully aware that there are members over at blurbusters who have done things along the lines of what you are asking.
Is the cap stored in the monitor's EDID?
