Disable msconfig in vista
Discussion in 'Networking & Security' started by Sirje31337, Nov 23, 2008.
  1. Sirje31337
    Sirje31337 Limp Gawd
    293
    Feb 19, 2002
    Title pretty much explains it. I did some googling and I can't figure out how to do it. You can't touch the file in Vista it won't let you do anything to it.
  2. Q-BZ
    Q-BZ [H]ard as it Gets
    18,290
    Sep 28, 2007
    Why would you even want to do this?
  3. Pepster64
    Pepster64 Limp Gawd
    332
    Mar 19, 2004
    Setup up different accounts and don't give the others users the privilege of using msconfig is the only way I can think of doing what you want to do.
  4. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
    Are you sayings yours doesn't work? Works fine on mine.
  5. SpaceHonkey
    SpaceHonkey Gawd
    983
    Jan 25, 2007
    Google "RestrictRun"
  6. Sirje31337
    293
    Feb 19, 2002
    No it works. What I meant by that was that I am unable to change file permissions, for example.
  7. Sirje31337
    293
    Feb 19, 2002
