DirectX problem
PianoRed
Ok, so I literally just got a new build up and running a few minutes ago. Everything seemed to be running fine so I thought i'd pop in Call of Duty and put my GPUs through their paces.
Only problem is that the program wouldn't start. Ran dxdiag and it said that none of the DirectX 11 features, which I presumed would've been enabled automatically, are available.
I'm far from a software junkie so I have no idea what I may be overlooking.
That's the fast track to getting account warnings/banned around here.
What exactly do you mean? Does it say DirectX Version: DirectX 11?
Download this utility. It will scan your system and install any DX libraries/updates that are missing from your system.
