DirectX 9 vs. 10
DX looks "slightly" better :D
Damn, i wonder if 8800gtx can chew it up on high settings @ 1920x1200...
i wish they had a spliced view though. because its hard to tell the difference.
Yes Hard to tell. Grahicaly it realy looks the same.
The Difference is the reaction of fire to it s breath exhaust flow.
I think this might be some interaction uses with geometryshading. The fire is geometry that is offset by a wind power/flow vector.
Nice but yes it's some cosmetic interactive detail that Dx10 offers. Nice.
The big difference Dx10 give is the Geometry shaders and al it's fancy stuf Dev's can do with it.
This is a example of a use for it. I think?
I notice the difference. It isnt anything to go crazy about but i asure you once u go dx10 you wont wanna go back. Its like when u up the resalution on you rmonitor... once you do that you basicly screw your self and you dont wanna lower it every again. Thats why I would never go bigger then 22 inch lcd becuase i wanna stick to the 1680x1050.
Also i never knew this game has such amazing physics and graphics. I MEAN WOW!!!
I wish they make a predator game using this engine. Love the jungle setting
wtf?
this game isnt out.......how do you have an opinion over dx10?
He was speaking generally about dx9 vs dx10...not specifically related to crysis
FYI: Lost Planet is a dx10 app, and honestly, it runs friggin sweet and looks nice...even though my GTX is only pushing 40 some fps. dx9 Lost Planet looks kind of dumpy. :(
The devs themselves have said that there are no new effects in the DX10 version, it only uses that for more efficient rendering.
I believe it was 20 or 40% more efficient. Whatever, if it means not spending $500+ to get that killer GC then so be it!
Looks nice, extra small details sure make a nifty difference in DX10 version. We'll have to see what the final product will be like, but I think going DX10 might be worth it. :cool:
