DirecTV westinghouse LCD remote codes
CocoBee
If any of you are having problems finding the right remote codes for your westinghouse display and are trying to program your DirecTV remote control to control the tv (westinghouse monitor), I've found the codes. It uses the sony codes. The one that worked for me is 11100. Other sony codes are 10000 and 10834. I hope this helps with problems finding the right remote codes.
