lilpoopypants
- Jun 29, 2003
The machine is a 82810E intel board using onboard 810E graphics. P3 660mhz and 320MB ram, Windows 2000 with DX9C.
I installed the latest onboard video drivers from intel and nothing changed. I uninstalled them an reinstalled, no change.
What I'm referring to is within dxdiag under display. I can only test directdraw but it errors out when it tries the fullscreen.
Heres the notes from dxdiag
Ideas/suggestions? I'm trying to get counterstrike to work on this old beast.
I've read the 810 is about equivalent to a TNT1, which should work in 640x480. I have no PCI cards available to use with it. Just an old ATI rage turbo pro AGP, which i have no agp slot for.
thinking about ordering a $60 geforce fx 5200 for it (its my machine at work)
I have the bios to the latest version (2001) and have as much memory allocated to the onboard as possible.DirectDraw test results: Failure at step 20 (Colorfill to back buffer): HRESULT = 0x887601c2 (error code)
Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
