TeleFragger
- Nov 10, 2005
Ok so... I was reading a thread where someone put WHS in vmware.... that is all great and dandy.. I thought about doing that and when I did.... that means all your files/backups would be through .vmdk files.... is there a way to tie a VM (esx4i) running WHS as the guest OS have direct access to a physical hard drive?
so if the vm went down you could then remove the drive and put it into a different computer and get to your data......
possible?
possible?
